Does anyone know the Honda part number for a sub filter for a 98 1500SE ? I'm sure it's probably already come up on this site somewhere but I can't see it. Thanks
Is way cheaper to buy this ($1) from Walmart, and cut it down to the size you need... be sure to use air filter oil on it (eg Same as for K&N Carb Filter). Makes the equivalent of about 20ea of the Honda filters (Sub Carb or Cruise), at less than the price of one!
"Duck Foam Air conditioner Filter (1/4" x 15" x 24")"
http://www.walmart.com/ip/Duck-Foam-Air-Conditioner-Filter/17133827
Honda Filter: FILTER, SUB A/CLNR 17253-KT8-000 $2.50
Does anyone know if it is possible to just take the right fan out and change that filter?
Any hardware store that has lawnmower parts will have air filter foam that you can carve one from.
> Not possible. (Unless you are one of those rare people who can change spark plugs by putting your arm up the exhaust pipe, JK!)
I sure felt like i could do the impossible after changing the thermostat, hoses, and orings this spring. lol
Monkey with a Football
I don't like oil on those or any semi-passive filter.
I run mine dry just like Honda did in the first place.
Discussion Starter · #9 ·
Thanks a lot Jim_C, exactly what I was looking for and I've just ordered a couple from Cyclemax. Cheers. John
Pwhoever
Not trying to second guess you but if you look in the factory service manual under fuel (Mine lists this in section 4-19) it specifically says to oil the sub air filter. The cruise filter stays dry but Honda says to oil the sub air filter.
