1 - 15 of 15 Posts
Does anyone have a recommendation on what brand of timing belt to buy? Napa and Gates both make the belts as well as Honda. Any recommendations are welcome.
NAPA#250-275 :shock:
Gates#T275. :shock:
Honda# 14401-MN5-004 :gunhead:
Eric Gardner :15green:
buy honda they work well and hold up not much different in price.piece of mind is worth something
Budegan wrote:
I think the Napas are made by Gates anyway.
NAPA contracts out for parts, but right now at the NAPA store near me the supplier of belts which fit the 1200 and 1500 is indeed Gates. I don't think you can get better, an old Huges 269 helicopter I took instruction in had seven Gates belts that connected the engine and transmission. If it was good enough for that, it's good enough for me!
:waving::15red::waving:
napa,gates as there cheaper and just as good used by most european car manufacturers. ;)
poffy74 wrote:
is that the correct Napa part number? napaonline says that part number doesn't exist?
Got this from the tips section of the site;
GL1500 Timing Belts. From May 2001, Gates have been supplying the T275 timing belt for the GL1500.[/b] Also available is the Napa 250275.
Other side of the pond
crohnshilton,those part nimbers you listed,am I to understand there good for the 1200(84) also......lost the numbers I had written down for safe keeping:gunhead:.....thanx.....Bob
According to Steve (Wingnut) in Goldwing Tipsthe correct NAPA number for the 1200 is 250070.
no sooner did I finish sending the question,my dear better half found my clymer manual that has all that info written down for safe keeping.I accused her of hiding the manual anyway;)......thanx for the help.....Bob
The wingnut is right, 250070 for the 1200 and Napa 250275 for the 1500. That means the belts for the 1200 and 1500 are different. the only two Goldwings that share the same belts are the gl1100 and gl1000.
Of course the Wingnut is right, after providing this website even if he was wrong he'd be right!:goofygrin:
Amen to that Paul. Redwing must be getting worried. Your post count is suddenly near the 900 mark. I think there is a prize for 1000, I wonder what Redwing got for his 1000th? :clapper:
The secret is in Shakespear, "...full of sound and fury signifying nothing!"
1 - 15 of 15 Posts
