1 - 20 of 48 Posts
there is rubber bushes on there,not sure if im leaving shocks in origanal place or moving to rear of axle,have many ways in my mind,will decide as work carrys on,
Discussion Starter #11
not sure what brakes i am going to use yet.these will be drilled out and have inserts,and will use 12mm bolts to hold in place,this will make it easy to remove if need be.
Discussion Starter #12
lots to do, am going to leave the axle the origanal width,nice and wide,soak up the road ahead,:cheesygrin:not sure about body yet,no cash,little bit at a time,thanks for looking
Discussion Starter #17
intend to fit the origanal air shock on the top of diff,at the same angle as the other shocks.
Discussion Starter #18
lot of cleaning to do before paint,will get drive shaft done and all the other stuff before stripping down to paint.
Discussion Starter #19
will leave brakes untill last,as not sure if using discs or drums.will all depend on the price and how much i :sadguy:have to spend
1 - 20 of 48 Posts
