Can someone tell me how the rear trunk light comes off? I need to replace one of the small bulbs in the center (I think they are 194's). Ilooked in the trunk and removed two nuts from each end and four screws but somethings still holding it. Is there screws on the bottom as well?
The Irish Crew
Drop the lower trunk cover and you can replace the bulbs. You don't have to remove the light unit, which isn't easy to remove anyway. Four screws hold the trunk lower cover on.
Alan is correct. They are small capless push in bulbs, you will see the rubber sockets when you drop the cover.
Thanks guys !
