Hello!
I was just going through the parts manual for the GL1500 using the term "filter" as the search word.:readit:
It came up with 5 more filters on the bike I was not even aware of-:shock:
Filter, Air Pump- 38752-MN5-003 *this is listed as #20 in the description, but it is not shown on the diagram.
Filter- 52717-MN5-003 *this is part of the Air Pump Assembly
Filter- 52716-MN5-003 *this is part of the Air Pump Assembly
Filter, Air Pump, SE '96 '97 '98- 39280-MZ3-770
Filter, Alternator, SE '96 '97 '98- 39280-MZ3-005
:wtf:
Are these filters important? Do they need to be cleaned or changed periodically? If so, how often?
Why aren't they on the schedule of filters to change or clean?
Thanx!
2000 GL1500SE
I didn't look up the part # on these but I would bet at least some of them are noise filters for the pump and alternator. They keep the electrical noise down.
· Pwhoever
That #20 filter is probably the little D-shaped filter that is inside a rubber cap that fits on the lower part of the air compressor. If you take a look at the first photo in THIS THREAD, you will see the rubber cap on the lower yellowish colored part of the air compressor. That thread is also a great guide on how to service your air compressor.
The 52716 & 17 are white filters inside the air pump assy with the desiccant. You can reuse the desiccant by butting it in the oven but for $5.50 I just bought new.
38752-MN5-003 (in the green) there is a rubber boot on the motor for the compressor (pull it back) there is a "D" shaped filter in there. And yes the "D" shaped filter should be changed out when servicing the compressor.
The other filters look to be noise filters for the cb.
