Clutch and throttle also both have a micro switch
The micro switches (2) at the clutch lever should click two times when you pull the clutch lever in to the hand grip. The 1st click (right away) is the cruise cancel, 2nd click (as it nears the hand grip) allows the bike to start in gear. (If the side stand is up and clutch pulled in to the grip)I've found the switches- not sure if a wire was off one of them, might have come off when I pulled the rubber boot back. The switches test ok. Do you know if the cruise engages when the bike is running in o/drive on the main stand or does it get an input from the speedo and only engage at a certain road speed. Thanks...Steve
And the rest of us get some great info......Thanks alot guys!!And thanks to this wonderful forum, another problem goes away!!! Nice work guys! jimsjinx
