Hi it appears this part is no longer avaialble under the many different part numbers, as I am replacing the thermostat and piped and I have a leak at the Carb heat Exchanger I was going to replace this part while the bike is stripped down however I have been unable to find a part , so can anyone advise if mine fails when tested can it be bypassed by a hose ?
19330-MT8-004 VALVE, THERMOSTAT - ALL '90
19330-MW5-004 VALVE, THERMO - ALL'91
19330-MY4-004 VALVE, THERMO - ALL'91
19330-MN5-004 88-89
19330-MZ3-621 88-89
If you are referencing part # 6, yep no longer available from Honda.
https://www.partzilla.com/catalog/honda/motorcycle/1988/gl1500-a-gold-wing/water-pipe
The correct (updated) part number for your 1988 is 19330-MZ3-621.
1988 - 1989: 19330 MZ3-621 and 19330-MN5-004
1990: 19330-MY4-004 and 19330-MT8-004
1991: 19330-MY4-004 and 19330-MW5-004
1992 - 1993: 19330-MY4-004
1994 - 2000: 19330-MZ3-621
Don't know of anyone who has bypasses this valve....!
If you need to get a used part, you know what years are compatible.
Hallo pricedjohn
And good luck with your Wing.
