GL1500 wiring diagram
2524 Views 7 Replies 3 Participants Last post by  coolhaven
Hello guys I`m looking for a wiring diagram? one that shows how all the wiring is run on,in,and around the frame..picked up a complete basket case trying to put it back together as close to factory as i can get..... its a 88 goldwing......thanks in advance..mark
ps. looked all though factory service man. did not find it there wiring yes how its ran no.
Look for a downloadable electrical troubleshooting manual.
it won't show exactly where the wiring goes but will get you pointed in the right direction.
Thanks dave....discovered that one last night... trying to find one that show the complete lay out....which might be a pipe dream...but who knows? hehe maybe someone!
Hey guys looked and looked fora wiring diagram showing the main wiring harnessand how its ran on the frame.. no luck so.....if any one has pics of a wing taken down to the frame for repairs or whatever showing any part of the wiring that would be great..found some on ebay helped a little...thanks.........mark
If you go to the component location pictures section od the ETM and go pic by pic you can see where all the components and connectors go. Begin by laying the harness on the frame and locating where everything plugs in. You should be able to figure out exactly where it routes by that method.
Thanks dave I`ll give that a try.......The reason i`m looking for pic etc. is i`m working on a basket case....with parts everywhere. PO completely disassembled the bike it is a bare frame bare engine...every sensor,relay.etc is all in parts all over the place. i can put it all back together. just like to see one with itall together.. far better to have a complete pic. of everthing is all.....thanks.......mark
Also look for the parts manual for 88-90's
Don't know if this helps any or not....
Thanks oldnewbie........found that pic just the other day...went to bikebandit.com they had all of those.....every little bit helps......thanks guys..................mark
