Simple stuff first, check your kill switch.
Starter Relay "B" should be receiving 12 volts on the coil side of the relay when the starter button is pushed. It also receives 12 volts on the contact side when the starter button is pushed. The difference is the "coil side" of Starter Relay "B" is fused.How much voltage should be going to relay b?
