Hi Whats the part.code for the H4 headlight bulb ( hid )
I believe from 98 to 2000 they are different ?
The part # for the stock bulb is 34901-MS2-672 . If you want HIDs that is a completely different thing with bulbs, ballasts and a wiring harness. You would find those on ebay. The standard H4 bulb that fits 88-97 requires a shim to fit the 98-2000 headlight.
  • Like
Reactions: Bike...and Dennis
1998 GL1500 Asp and 2017 GL1800 4AC
Just in case this is what you were asking about, The 1998 through 2000 headlights require a special bulb from Honda due to alignment tabs that are in a different position than a standard 9003 or H4 aftermarket bulb.
OR - You can buy Headlight Bulb Shims for 1998 - 2000 GL1500's. Cyclemax of Ohio and a few other vendors carry these shims. The 1988-1997 style headlight does not require these shims to use aftermarket bulbs. These will work with either halogen or LED H4 bulbs.
