· Registered
I am having some issues with my Fog Lights not coming on. The button is to the right of the Hazard button, and I am assuming that the button being in the down position means they should be on. Fuses were all checked.
If someone can share there knowledge about this it would be appreciated.
· Old School Guru
Probably the relay under the left pocket is bad, or the switch itself have been known to go bad. Both items are easily replaceable, and you can get them cheaper from Cyclemax than from the dealer.:) With a voltmeter, it shouldn't be hard to check either one.:)
Gene:waving:
· Registered
Gene:waving:
Thank you Gene, I will try to find the relay under the pocket. I was going to check the bulbs with my meter but now I will look for the relay. The switch will be a lot harder to get to.
I just finished replacing the dreaded "Air Filter" which took 3 hours, but all other controls are working fine on the left control panel.
· Senior Member
First thing = check bulbs !
The swith is nown to get stuck in the on position , so those bulbs could have been powered for wery long period .(and some aftermarket fog ligths are not Honda quality ).
· Registered
Discussion Starter · #8 ·
It was dirt in the switch. While I had the control out of the bike I also repaired my Hazard Light switch as it was sticking badly. First I used compressed air, then I used Electrical Contact cleaner, and finally I used some more compressed air. Switches work like new, both of them.
Thanks for all your input!
Kenny G
