Is there anyone that have an idea what can be wrong? The grip heat and the seat heat is not working and the fuse is ok and the harness at least looks ok.
I have heard of owners replacing the air filter, and not getting the wires plugged back in all the way, or at all.
Tom Bishop
`98 S.E.
the first step in the manual is to remove the seat but DO NOT unplug the seat, then unplug the green connector from the relay box and exchange the relay with a known good relay. I know that is not much help, but if the relay is good then you check the ground wire for the heater control unit.
I would unplug and check the connectors for the seat and make sure the the # 11 fuse is good (with a meter) and go from there
