1 - 3 of 3 Posts
Hi out there in Goldwing land. Got a problem and wondered if anyone can offer advice. The brake lights to my GL1800 are stuck permanently on. Have cleaned and checked operation of switch to rear brake but not sure where to go from there.
First with the side cover off watch the operation of the switches on the master cylinder rod. If it looks like the metal tab is working both switches then listen closely while you push the pedal down slowly and let it up, there should be 2 clicks each way. If OK then listen at the front brake while you pull the lever, there should be 2 clicks each way on it also. If you only hear 1 click a switch is stuck.
1 - 3 of 3 Posts
