How do you get to the front signal light bulb on an 1800. Used the forum search and havent found anything.
Are you talking about the one in the mirror?
yes the one on the mirror
In the bottom of the mirror housing there is a hole allowing access to a screw that is holding the mirror glass in place. Carefully remove it, then remove the mirror glass which will give you access to the light bulb. If you have air wings on the bottom of your mirror housing you will have to remove it (same result, different screw/bolt). Be careful when reinstalling the screw so as not to crossthread it.
Other side of the pond
Halfling is right. Be careful when you remove the screw as the mirror glass can fall out and hit the ground. Put your free hand over the glass as you remove the screw.
