1 - 15 of 15 Posts
I have an '03 1800. Several months ago, I began having problems with my CB Radio. I can hear my fellow riders clearly, but they say my transmission is very weak and garbled. I have checked the connections under the seat from the radio and the antenna, and have checked the set screws in the antenna. Two Honda dealers told me by phone that the problem may be the radio itself. Is there any thing else I should check first? Thanks.
Discussion Starter · #2 ·
I forgot to mention that I have also checked the helmet connection by using a friend's helmet and cord on my bike, and I got the same transmit problem.
hey Ron,
let us know what sierra electronics says about the c.b.
nice riding with you guys on sunday:thumbsup:
Sierra said to check the swr, but they think the "final drive" in the cb radio is shot. Got to find someone with a meter and who knows how to use it. It was a great ride Sunday.
If it is sending a signal and it is garbled then more than likely it is not the CB radio but the antenna system that is the problem. Make sure you check the ground strap in trunk for a crack, about 1 1/2" from the bolt at bottom of trunk, as I am seeing this as a problem.
Discussion Starter · #9 ·
Don't know if it makes any difference, but the transmission is more "weak" than garbled, but I'll check the strap tomorrow.
Discussion Starter · #11 ·
The distance doesn't seem to matter. The last ride I was on had 15 bikes. The rider just in front of me said the transmission was weak, and the others didn't hear me at all.
To me it sounds like the finals in your CB are shot. They are the transistors that control the power output when transmitting.
The SWR meter also has a Db/PWR set up (at least on the old ones) that you insert a very small antennae to and walk around the unit when transmitting and you can see the transmitting pattern. A weak indication will tell you if it is the problem.
Good Luck.
:18black:
I agree with Sierra radio discription, it sounds as if you final amps in the radio are out and you maybe just operating on the pre-drivers. Bad finals will cause distorted audio and just operating on the pre-drivers will give you a very weak signal.
if you have access to a SWR meter put it in line and check you antenna system, it will also let you know if your radio is producing any power.
Discussion Starter · #15 ·
Wayne, the problem may have been solved. I didn't find any crack in the ground strap in the trunk, but I did back out and retighten the bottom ground connection bolt a few times. Afterwards a friend and I went for a short ride to test it at different distances. He said he was able to hear me loud and clear. Thanks for suggesting it may be a ground problem, and thanks to all who offered advice.
1 - 15 of 15 Posts
