1 - 17 of 17 Posts
does anyone know the following of the construction of this color.
Honda PB304M Pearl Apollo Blue
Ground Color?
Base color PB304M
Maybe a top color????
varnish
Itwill help me
Henk
that's not what I'm looking for..
I'm looking for what color basis ( ground). should I use for this color
White, beige, black?
Can I also buy the color here, but who do not know what color background
A good auto paint supplier/store with a color scanner will get that for you with a chip. Most likely you won't find that on here.
mebey some here paint his trailer.. and the men now.. you dont now..
The word is MAYBE and KNOW
Like I said most won't have that info or even how to get it.
Other side of the pond
There is no base colour for the PB304M Henk, the "Pearl Apollo Blue" isn't actually a pearl type paint. It is just a metallic blue colour which you clearcoat over.
It is also an easy colour to get matched in a car paint suppliers.
oke but.... i have the paint here
when a paint with underground color light broun than is de bleu color dark bleu
when a paint with the same color with undergound than is the paint lighter..
oke.. i must look whats is the best foor my bike..
thanks..
I am only asking, because I am by no means certain, but aren't the panels for the Goldwings coloured through, so not a different colour under the paint. :?:?
Discussion Starter #11
but you must be a painter to now this.. under the color candy red you must paint Silver..that i now for the good color..
i tested yesterday again and i have 2 different colors..
and ask colorrite but i get now anser..
Senior Guru
The Honda reds are done differently, ie 3 stage paint. Silver or sometimes black base, then colour coats and finally clearcoat.
Some Honda colours are pearl (yellows, whites, some blues) and have a flat pale colour (pale yellow for a yellow finish, for example), and the pearl coats go over that. Clearcoat on top.
Some other Honda colours (greens, some blues, blacks) are standard metallic with clearcoat on top. pb304 is one of those, ie no base colour.
hey newday ,give the guy a break , he does not speak English ,as you can see his from NL Holland and if you ask me his spelling is much better than a lot of the people who mother language is English ..we are a motorcycle forum not a language school :):)
Henk I do not know a lot about paint ,but as far as I know most goldwing panels are painted in the USA and they use acrilic paint (oil based) and we in Europe only use waterbased colours as acrilic is banned in Europe and that is why it is almost impossible to match the Honda colours here .
Someone who knows paint in Europe might chime in and clear this up .. Ciaran
In most of Europe water based paint is only compulsory for spraying cars, we can still buy the motorcycle colours.
PPG do an excellent match for PB304M, I've used it myself on a couple of 2001 GL1800s. The PPG match is just a metallic base coat and you spray it straight over the primer. Clear lacquer on top.
Discussion Starter #17
wingern-nl wrote:
thanks Wexy and Steve,, about my english.. is always better than his Dutch.. i tray it and you understand me.. hahaha
and i paint never with waterpaint.. Steve always withoil..
thanks... FROM HOLLAND...
1 - 17 of 17 Posts
