· Registered
Hello, newbie here, 08 GL 1800 Goldwing trike. When I engage main cruise the light comes on but when I hit the button to set it it blows the fuse. This is the second time it has happened and I tried to ride it home and as I was riding all the gauges went out and it was losing power so I pulled over because I could see on my voltmeter it was draining the battery. I replaced the fuse for cruise and everything went back to normal. I don't try to use it anymore for right now but any suggestions on this issue.:wtf:
Thanks,
Vince
Augusta, Ga
· Administrator
The short almost has to be in the br/wt wire to the actuator. I would suspect the area where the wiring is near the front of the left radiator.
