Im new here myself and in the process of ground up rebuild of 85 aspy as far as your problem first thin I would check is altnator plug at the left side of batt. box to see if the connector was getting hot then check between alt leads for short or open . you'll need an ohm meter for this.This is and has been a problem area for 84-87 gl200
