GL1800 Fault Indicator Lamp codes ( FI light )
11334 Views 9 Replies 7 Participants Last post by  rcgreaves
this info has been lost in various posts with thread names not relating to the actual codes, so I am creating a thread with the actual name for this code list.
_______________________________________________________________
FI or Fault Indicator codes
If FI (Fault Indicator) light comes on pull over but DO NOT shut bike off. Put in neutral and put side stand down, RPM’s below 1500. This signals the ECM to send the error code to the FI light. Count the number of long and short flashes. This will give you the error code. Also known as Malfunction Indicator Light (MIL)
If you shut the bike off the error code is lost - sort of. It will be retained in the ECM but it is harder to get out. If the bike stops and will not restart you can get the FI light to flash the error code by cranking the engine for 10 seconds. The FI light will then flash the error code.
Long Blink = 10 Short Blink = 1
i.e. long long long short short short = 33 check error code 33
Number of MIL blinks .Symptoms
.Cause
0 No blinks • Engine does not start
• Open circuit in the power input and ground wires of the ECM: • Faulty bank angle sensor
• Open circuit in bank angle sensor related wires: • Faulty FI IGN relay: • Open circuit in FI IGN relay related wires
• Faulty engine stop switch: • Open circuit in engine stop switch related wires: • Faulty ECM: • Blown FI IGN fuse (20 A)
• Blown ST. KILL fuse (10 A):
0 No blinks • Engine operates normally
• Open circuit in MIL wire: • Faulty combination meter: • Faulty ECM
0 Stays lit • Engine operates normally
• Short circuit in service check connector wire: • Short circuit in MIL wire: • Faulty ECM
1 Blinks • Engine operates normally
• Loose or poorly connected MAP sensor connector: • Open or short circuit in MAP sensor wire: • Faulty MAP sensor
7 Blinks • Hard to start at a low temperature (ECM controls using preset value; coolant temperature: 85° C/185° F)
• Loose or poorly connected ECT sensor connector: • Open or short circuit in ECT sensor wire: • Faulty ECT sensor
8 Blinks • Poor engine response when operating the throttle quickly (ECM controls using preset value; throttle opening: 0° )
• Loose or poorly connected TP sensor connector: • Open or short circuit in TP sensor wire: • Faulty TP sensor
9 Blinks • Engine operates normally (ECM controls using preset value; intake air temperature: 28° C/82° F)
• Loose or poorly connected IAT sensor connector
• Open or short circuit in TP sensor wire: • Faulty IAT sensor
10 Blinks • Engine operates normally at low altitude
• Engine idles roughly at a high altitude (ECM controls using preset value; barometric pressure: 760 mm Hg/1,013 hPa)
• Loose or poorly connected BARO sensor connector: • Open or short circuit in BARO sensor wire: • Faulty BARO sensor
11 Blinks • Engine operates normally
• Loose or poorly connected vehicle speed sensor connector
• Open or short circuit in vehicle speed sensor wire: • Faulty vehicle speed sensor
12 Blinks • Engine does not start
• Loose or poorly connected No. 1 injector connector: • Open or short circuit in No. 1 injector wire: • Faulty No. 1 injector
13 Blinks • Engine does not start
• Loose or poorly connected No. 2 injector connector: • Open or short circuit in No. 2 injector wire: • Faulty No. 2 injector
14 No blinks • Engine does not start
• Loose or poorly connected No. 3 injector connector: • Open or short circuit in No. 3 injector wire: • Faulty No. 3 injector
15 Blinks • Engine does not start
• Loose or poorly connected No. 4 injector connector: • Open or short circuit in No. 4 injector wire: • Faulty No. 4 injector
16 Blinks • Engine does not start
• Loose or poorly connected No. 5 injector connector: • Open or short circuit in No. 5 injector wire: • Faulty No. 5 injector
17 Blinks • Engine does not start
• Loose or poorly connected No. 6 injector connector: • Open or short circuit in No. 6 injector wire: • Faulty No. 6 injector
18 Blinks • Engine does not start
• Loose or poorly connected camshaft position sensor connector
• Open or short circuit in camshaft position sensor wire: • Faulty camshaft position sensor
19 Blinks • Engine does not start
• Loose or poorly connected ignition pulse generator connector:
• Open or short circuit in ignition pulse generator wire: • Faulty ignition pulse generator
21 Blinks • Engine operates normally
• Open or short circuit in right O2 sensor wire: • Faulty right O2 sensor
22 Blinks • Engine operates normally
• Open or short circuit in left O2 sensor wire: • Faulty left O2 sensor
23 Blinks • Engine operates normally
• Open or short circuit in right O2 sensor heater wire: • Faulty right O2 sensor
24 Blinks • Engine operates normally
• Open or short circuit in left O2 sensor heater wire: • Faulty left O2 sensor
25 Blinks • Engine operates normally
• Loose or poorly connected right knock sensor connector: • Open or short circuit in right knock sensor wire: • Faulty right knock sensor
26 Blinks • Engine operates normally
• Loose or poorly connected left knock sensor connector: • Open or short circuit in left knock sensor wire: • Faulty left knock sensor
29 Blinks • Engine stalls, hard to start, rough idling
• Loose or poorly connected idle air control (IAC) valve connector: • Open or short circuit in IAC valve wire: • Faulty idle air control valve
33 Blinks • ECM does not hold the self diagnostic data
• Faulty E2-PROM in ECM • Engine operates normally
41 No blinks • Engine operates normally
• Loose or poorly connected connector in gear position switch related circuits
• Open or short circuit in gear position switch wires: • Faulty gear position switch: • Faulty clutch switch: • Faulty side stand switch
Engine cranks but won’t start
• No fuel in tank, • No fuel to injector, – Clogged fuel filter, – Pinched or clogged fuel feed hose, – Pinched or clogged fuel tank breather tube, – Faulty fuel pump, – Faulty fuel pump circuits, • Intake air leak, • Contaminated / deteriorated fuel, • Faulty fuel injector, • Idle air control valve stuck closed, • No spark at plug Faulty ignition system
• Restricted fuel feed hose, • Contaminated/deteriorated fuel, • Intake air leak, • Faulty idle air control valve, • Restricted fuel tank breather tube, • Misadjusted idle adjusting screw, • Faulty ignition system
Afterburn when engine braking is used
• Faulty pulse secondary air injection (PAIR) system, – Faulty PAIR control solenoid valve, – Faulty PAIR check valve, – Clogged hose of the PAIR system, • Faulty ignition system
Backfiring or misfiring during acceleration
Poor performance drive-ability and poor fuel economy
• Pinched or clogged fuel feed hose, • Faulty pressure regulator, • Faulty ignition system
  • Like
Reactions: 3
I have a 2003 GW while on the road with plenty of gas the F1 did not come on after a rest break. Bike was unable to start even jump starting by rolling down a hill. No F1 indication on when key is turned on.. will crank but no ignition..Open up fuel tank 7 V dc to from center to 3 terminals No fuel is produced.
I believe the correct acronym is "MIL", or "Malfunction Indicator Lamp".
Yes, in the automotive world that is correct. The mechanics often refer to it as the "money light". 😃
I refer to it as the PITA light on cars since a good part of the time it's because they didn't tighten the gas cap or left it at the station.
  • Like
Reactions: 1
How do you shut off the light after fixing the problem?
In most cases it will clear itself when the problem is resolved.
7-19-2022 My code 11 VSS fault has not cleared itself. Soo unsatisfying....no apparent damage to the harness. What now?
Did you fix the problem?
Yes and no. I downloaded and studied an OEM service manual. Turns out the 2001 to 2003 DO have a memory clear procedure. I started another thread and posted it there if interested, or query and I'll repost. Essentially you short the test plug with the FI illuminated and ignition on. I may not have that 100% Tomorrow I'll give it a try.
