gl1800 fi light
1560 Views 4 Replies 4 Participants Last post by  DaveO430
fi light comes on on my gl1800 goldwing engine stops but restarts any one no reson for rthis fault
Hi and welcome to the forum if you click on the link you may get your answer then just go to the f section it has the prob listed there
http://www.goldwingfacts.com/forums/drwIndex.php
How many times does the FI light flash so we can determine the fault code? A fault code 1 with engine cutting out can indicate a failing MAP sensor.
If it isn't a fault code 1 then you could be lucky to just have a bad oxygen sensor. I don't remember the code for that and I have to go out now, one of the guys here will probably get back on this soon.
Where are my manners? I forgot to say welcome to the forum!
Put the side stand down and start the engine, do not touch the throttle. If there is a code stored it will flash. long flashes = 10 , short flashes = single digits. Get back to us with the code. If no code is flashed check your battery connections.
