Can anybody provide any tips to replacing a heated left grip. I have tried soapy water-no luck, and rubbing alcohol-no luck. I cleaned the bar good and don't want to damage the new grip during the install. Any help would be greatly appreciated.
Thanks in advance,
Rob
Warm grip on a cold bar and spray liberally with hairspray to hold it on.
2000 GL1500SE
After use of the hairspray, then push on the end of the grip to shove it on. Don't hold the center or the end closest to the switches. Pushing on the outside end of it will help to spread the center a little, "fatten" it, so it will go on easier.
