1 - 20 of 22 Posts
I am an owner of a motorcycle repair shop. I have a customer's 2001 Gl1800 that makes a growl noise at idle and during decelerating intermittently. I used a stethoscope and noticed it was noticeably loudest on the alternator. I replaced the alternator and it didn't make any difference. So now I'm thinking it might be the bearing that is inside the crankcase but I'm looking for other options and if anyone has heard of this problem on an 1800
It only has 45k for miles
Mine sounds terrible, always has, I'm about 1 ride from 100K and my 08 sounded the same. It is worse since the last oil change, I bought some Castrol GTX motorcycle oil, going back the the rotella next time.
1984 Aspencade
My 2010 growled from new. It was finally discovered that 2 of the front fender bolts did not have rubber washers. Quieted right down. I think, a dealer told me that is the way they shipped from the factory. Too long ago. Someone can correct me.
This is most likely not your issue, but thought I would throw it out there.
2003 GL1800A
Pretty sure only two of my front fender bolts have ever had rubber washers - and now they're new ones since my last trip to the dealer resulted in one of them going missing, and one of them magically transforming into an O-ring :mad:
Have you pulled the engine yet?
A bad ACG (What Honda calls it) growls at idle. Sounds like ball bearings in a can.
The noise should go away as you roll on the throttle (1,000-1200 RPM's)
The problem is the Stamped steel collar that is supposed to hold the two Half clips in place.
Middle Bottom in the picture.
324644
The Retainer is supposed to look like this.
324645
The OEM Retainer is so sloppy from Honda. that it eventually the centrifugal force causes the clips to break the retainer at its weakest point (Where the tang is)
A good retainer next to a blown out retainer.
324646
I made a custom Retainer. Its been in my ACG for 9 years now and 84,000 miles.
324647
Honda changed the ACG design in 2006-2017.
They still fail, mileage makes no difference.
My first ACG went out at 37,000 (Due to warranty I couldn't replace the weak retainer)
The second ACG went out at 93,000 miles. At that point my warranty was out.
This is when I installed my Custom retainer in 2011. I haven't had a ACG issue since then.
I work on Goldwings and have all the tools needed to rebuild the whole engine. (You only need a few to remove the engine from the frame, and get the rear cover off to access the ACG.)
You should replace both ACG bearings (F&R)
BTW- there were a few guys who changed the older 01-05 ACG for the fluid dampened ACG starting in 2006-2017
Only to have it too fail after the mileage racked up.
Feel free to PM me if you have any questions. (Or where to buy the Improved retainer & removal tools)
I have a friend with a 2010 that has had a rumble from his since new. (I used a mechanics stethoscope on his.)
His rumble is nothing like the noise from the 01-05 ACG's.
He has 86,000K on his now. His ACG hasn't failed yet.
I bet you both have loose fitting ACG bearings.
Mine is not nearly as bad as in the video & as I said, it is almost 100,000 miles and my 08 did it from new and had 122,000 on it.
Discussion Starter · #17 ·
A bad ADG (What Honda calls it) growls at idle. Sounds like ball bearings in a can.
Well, I finally did get the ADG replaced and the noise is gone.
Hi. I've seen the posts about the 1800 ACG repairs. I am doing an ACG replacement for a customer (2003). At the moment I'm having trouble locating the actual part (13430-MCA-780). When I do, I would like to replace the washer before I install it. Can someone help me locate the washer and or ACG. Thanks, Justin
1 - 20 of 22 Posts
