1 - 3 of 3 Posts
Im bleeding antifreeze after a short ride yesterday. seems to be coming from a plastic tank under bike just above center stand.any ideas???
Something probably punctured the recovery tank, common problem. A belly pan is a worthwhile investment just to protect that 1 item.
is the part that you are referring to cylinder looking and has one hose going to it? I had the same problem and turned out I just needed to clean it out and clear all the hoses. It connects pretty easily. Just a tight fit
1 - 3 of 3 Posts
