1 - 12 of 12 Posts
So, whats the trick? I cant get my hands in there following the instructions in the factory service manual.....
Have not looked at the manual for that but did you turn the bars all the way to the side you are working on and reach in from the rear?
And what state is King Geroge in?
Senior Moment Member
I've been through a King George on my way to Dahlgren VA for some software testing while working on some Naval Ships Weapons Systems.
I wonder if that is where he means.
Henry
Should not be a problem , turn the bars to one side and put your hand down ,first time can take a while trying to find your way ,But once done once it takes about 5 mins to do ,,
I don't know about 5 minutes, after I get them in I think well next time that won't be as bad but the next time it needs to be done about 2 years have gone by and I stand there and say (HOW DID I DO THAT LAST TIME).
I put the HID unit in last week and it is suppose to last longer so we shall see, if they do need to be replaced I will have to remove the top shelter to put in new bulbs now because of where I stored the sending unit. You can get your hand in there but look at the way the bulb sets into the slot and make sure the clip is all the way out of the way when you insert the bulb and it wont be that bad, good luck:popcorn:
Henry
His profile doesn't say King George, it says King Geroge, USA
Henry
I saw that and thought he might have made a typo.....lord knows I make enough of them!!
:ROFL::ROFL:
Henry
YUP I am a retired Chief Firecontrolman and support the base.
I have fixed my profile to include my state.
Thanks for the reminder.
Discussion Starter #10
OK, I got the low beams.....
now, how do you change the high beams????????
Google GL1800 headlight replacement and you will get a bunch of movies and pics.
Discussion Starter #12
I think I need a few more wrists in my arm..... I still cant get the high beams.......
1 - 12 of 12 Posts
