If you are having problems with the PTT for the rider, 99 out of 100 the problem lies in the switch itself with dirty contacts. Wrap the area with a rag and spray liberial amounts of contact cleaner while working the switch. Or seperate the cluster and clean it that way.
Below is the plug under the left faring pocket from the left cluster, for the PPT it's the yellow(pin8) and green(pin10)
Hope this helps.
