Would just like some insight into Amsoil for my 1800.
How do you rate it and what should I be using.
Any advise would be great.
Brewy.
Welcome to the forum, Brewy. I moved this to the general motorcycle forum, so you will get more exposure, based on your question. When you get a chance, please enter your location.
Welcome,
Mike
You may want to do some reading here, there see how you feel.
Click Here - Oil
Probationary
One of the biggest problems with motor oil is the way it becomes corrosive [acids] after combustion in the chamber [hydrocarbons].
This makes 'intervals' more important than miles. This does not negate excessive miles, though.
Oil & filter should be changed every 90 days, regardless of mileage. Also, 3000 miles makes for much acidic content for engine parts to soak in.
Remember high school chemistry: Hydrogen mix = Acid.
Think about water[ H[suB]2[/suB]0] actually "oxic acid" = 2 parts Hydrogen & 1 part Oxygen ...mostly harmless during short-term, but eats through steel with long term exposure.
Then figure right oil to use for use& climate.
