1 - 3 of 3 Posts
On my 08 wing there is a power plug on the drivers left glove box with the aux sound cord. Does the radio have to be on aux to get power out of the plug? I have tried both ways and I don't get power I haven't opened up to check it yet other than the main fuse box and every thing there is good. The owners manual doesn't seem to say or I am missing something ?
Pete
The plug actually has a fuse in the wire just before it connects to the bike. you might try checking that. It could also be that the wire isn't plugged in. It's fairly easy to pop that pocket out, just push the center pins in on the plastic rivets and pull the pocket out. From there, you can get to the plug for the power port and the audio jack easily. The power should be available when the key is in the acc or on positions.
1 - 3 of 3 Posts
