1 - 14 of 14 Posts
You should repost this in the technical section.
You can replace the bulbs. Split the switch halves and you are in. It is a bit fiddly, and small fingers help.
The bulbs are tiny and come already connected to a wire and little connector. Part number is 35139-MCA-A20.
Like 07Silver says, 35139-MCA-A20 is what you need. Small fingers help too, a tweezers works if you have big hands.
How many bulbs are on the right side with the cruise and reverse? None of my buttons light up on that side (2004) and I want to be sure that if there are more then 1 that I order enough of them.
1 - 14 of 14 Posts
