1 - 2 of 2 Posts
The right headlight does not move when the control knob is moved.
The engine is running and the left light raises and lowers OK.
Is there an easy way to get at theright servo motor plug or do I have to take a
bunch of stuff apart to access it?
Harvey
Not a bunch but some: Take the front lower cowl(fairing off) then up high and against the forks the center inner fairing. You have to take the windshield garnish off to get to the fasteners for that wrap around lower cowl.
Then you can see the two small adjusters. For the right one you will turn it clockwise in the housing to release it. You first have to pull it out and release the stop pin that holds it straight. Then it twists out like a light bulb housing on a car. It has a gray 3 pin connector to it, so check that for being secure first.
Kit
Adjuster might have just bounced out of the plastic housing.
1 - 2 of 2 Posts
