A client send the message about whether I had a Hazard switch available for sale, and in response I wrote back the time tested rejuvenation method for those fiddly push-switches:
because the operate on a slide-rail or push-rod that triggers a spring operated catch.
Taking them apart is a nightmare, and very rarely can be put back into proper operating status.
I have corrected 50 of those if 1, and only three or four were past retrieval. Patience is key.
The problem lies is two factors:
If you are not close by, then you need two things:
Save yourself a switch, and then do the same to ALL switches on the bike, same method. Do it every year, and you don't even have to expose the switches: blow the two items in around the switches from the exterior, (Nu-trol to clean the contacts, lube to take care of the mechanical aspects) it'll 'walk' into the switch. Your switches will last many years longer. The above are my favorite time-tested products, but any good NON-DRYING contact cleaner, and any fine but excellent spray-in lube (NOT DW-40) will do the trick if used prior to the switch sticking. <<<<<<
PS: The client wrote back next morning and reported the switch was back into good operation.
That is a common occurrence. They never are maintained regularly, which they need to be. They are predominantly the switch-type that gets dried out and useless>>>>
- Typically it is ancient Honda grease which hardens over time, and
- That binds the little copper plate that is on a tiny spring (which is the real PITA when you disassemble the switch), and prevents the push-button flange from engaging or disengaging.
- A can of Nu-trol contact cleaner (by MG Chemicals) which will, with a very liberal spray into the opened switch housing and into the push rod runner of the push-switch (without removing the switch from the housing), which you will be able to see with the housing opened (no need to remove it from the bike, just get the back-panel off the suspension control panel, or the control switch off the handle bar). Inject the Nu-trol, which will basically ‘melt’ the old grease off. You may have to work the switch for a few minutes, and after pushing on it LIGHTLY for 10 or 15 tries, hit it with the Nu-trol again. At this point instead of simply pushing and releasing the button, push it in, and slide the thumb-finger sideways off the button to allow it to get full rebound off of that tiny spring. If it is stuck in, keep ‘snapping’ it like that, and it will almost certainly disengage after a while. If it is not engaging, keep doing it, and it eventually should engage. The VERY FIRST TIME it disengages (or engages) is the time to use…..
- A shot from a spray-can of EZ lube, (ask me where to get it if you can't find it) which is a super-fine turbine lubricant, which cleans oxidization off as well as lubricating. If you haven’t got any, then get a can is very fine lube which has cleaning properties, and try it. DO NOT push that lever back in until you have firstly again sprayed it with Nu-trol, then lube. Then do it lightly again. You may have to do the ‘snap’ trick a few times until it frees up fully. Once it is freely operating you are good to go. Maintain it regularly and it will stay good.
