Like said, yes.... YOur probably fine..
But there are reasons to be cautiousin considering it (partcularlly in the direction "conventional" to "synthetic")... As said, they are all mixable and provide lubrication per their ratings, but "non-synthetics" are notas well refined and contain a small amountof light oils and solvents that, over time (years), may expand/swellcertain gasket materials. "Synthetics" containmuch less (or none) of these solvents, so going from "conventional" to "synthetic" may allow, in time, theseals to shrink back, in which case, you may see oil seapage or leaks... (Going from "synthetic" to conventional is less of an issue.. ) Granted,modern seal materials are far less suseptable to this than "old-school" materials.. so little difference is expected.. but it is comething to consider.. and not just theory either.. I have actually experienced this in an old Ford.. tried synthetics, it leaked.. went back to conventional, and the leaks eventually resealed... On something as new as an 1800, I would expect that you would have no problems.
