1 - 11 of 11 Posts
I also have a 2002 Goldwing. My flashers (4 ways) will not work nor will my signals. I have checked the relay behind the speedometer, I have replaced the turn signal switch assy, checked the bulbs, checked the relay under the seat. It is driving me nuts. Where does the 2002 Goldwing have its ground or grounds for the signals/flashers?
Senior Guru
The common ground point for turn signals/hazards is on top of the engine a few inches to the right of the starter motor and a 10mm bolt secures it.
Have you determined that the turn signals and hazards are getting power from the ignition and through the 20 pin orange connector under the right side fairing pocket? A red wire on the ignition side runs to relay no. 5 (the turn signals relay).
I have checked the fuses, the turn signals do not come on nor do the four way (emergency flashers). The complete switch assy has been changed, bulbs checked, relay's checked. The cancel which runs down the triple tree has been checked.
Discussion Starter · #9 ·
Ok still trouble shooting we have confirmed that the signals do have a good ground and that the position lights do have 12 volts. But the turn signals do not have 12 volts. We ran a jumper from the battery to the signal positive wire and the light will light up. We will dig in deeper into the relay later after I get some sleep. What ever powers the turn signal light and makes it flash on and off is the problem I think...just needing more time to look for it. we have changed out the flasher button, left handle bar controls, the cancel switch up the triple tree, relay and diode behind the speed-o-meter, and disconnected all add on that have been put on the bike.
Discussion Starter · #11 ·
OK IT IS FIXED.......On the back of the speedometer casing there are three wires attached with screws (not the blue or black wired connectors behind the rubber covers below them) the center screw was loose it didn't look loose but we got several turns on it. Now my signals and flashers work properly. YEAHHHHHHH
1 - 11 of 11 Posts
