2007/gl1800, does any one know what the white electrical connector under the forward right compartment is. This connector has nothing connected to it. Everthing on the bike works fine:?,there are no problems.
Does it have a cap on it? If so just a place to plug in something not on the bike yet. What color are the wires and how many?
It might be for accessory heated grips. The only other white connector that comes to mind in that particular spot is one that's supposed to connect to the air temperature sensor that's mounted in the right side fairing...for the information button on your instrument panel. I thought all gl1800's had that feature. You may want to make sure yours works.
Look around the bike and you will find several connectors that are not used esp under the seat. If everything works then nothing is wrong.
