1 - 2 of 2 Posts
I saw the fluid in my window for my clutch was cloudy so I bleed my clutch lines and put everything back together and then noticed that the window for my clutch fluid was still cloudy, is there a way to clean the window, this is for a 2007 GL 1800.
rod
Rod
You could try and use a qtip to get behind the metal to wipe it clean. I haven't tried it but it might work. I just open the top up on the master cylinders of any system to know for sure the level and condition of the fluid.
1 - 2 of 2 Posts
