Using the lowest position as a reference:
How many notches up can it be raised and still tighten down on both sides?
I think mine is broken but, Iwant confirmation before I contact my local dealer for warranty service. First thru third notch all works normal. On the fourth notch up the left side tightens down fine. The right side will slip up and down a bit. It seems that this was not alwaysthe case.
If it is indeed broken, any idea what may have broken? Mind you if it is covered under warranty I'll let the dealer repair it; if not, I'll be doing it myself.
