1 - 9 of 9 Posts
i used a 80-90 on my 1500 and looking at cyclemax they have a 85-140???
i tought i read the honda manual and they mentioned a 90??? am i wrong?
which one would work better??
thanks
filippo
02 GL1800 w/Auto Pilot
The GL1500 transmission and engine oil are in the same crankcase system.
Unless you are talking about the rear differential case, that is a typical 80-90 gear oil.
yeeeeeep i am talking about the rear one!
so why cyclemax shows a 140?? would it be smother???
I'd stay with the 80 - 90 wt The heaver fluid may cause lube problems
wilf
I questioned Cyclemax about this and they definitely recommend the heavier oil. I was told it was from advice from a gob of Honda mechanics. I've been using the heavier stuff for 10,000 miles or so with no obvious ill effects.
Junior Grue
Probably fine in summer but what happens when you ride at near freezing temperatures?
My experiences with 80-90 and 140 hypoid oil in the rear of an 1100 indicate DO NOT USE 140 unless the ambient temperature is consistently high.
At about 80 F the 140 oil has a tendency to creep up the fill hole breather and come out and with the back wheel turning soon this hypoid oil will be all over the hub, the wheel and traveling into the rear brake.
A flush out and replacement with 80/90 wt solved the problem. Why did I use it? That was all that was available at that time. Big mistake, big mess, big clean up.
Like others here indicates, I'd stay away from the 140 if temps are getting close to freezing point. Talking of that, we got our first snow for the season here today.
Discussion Starter · #9 ·
Levanger? Where is it? My norvegian relatives are in branbu... Close to gran area... Uppeland
1 - 9 of 9 Posts
