Tomorrow I'm going to install a lighted override switch to bypass the ECU of my GL1500 so that in the event that a problem develops with any of the safety circuits, I can still get home.
In the event that something goes awry while on the road, by tapping into the main pin of the ECU, I can by-pass any safety circuits that could prevent me from starting the wing. For example, a bad BAS, or bad Neutral sensor etc. This safety switch will only be used if the wing will not start normally. By overriding it, I can finish my trip and troubleshoot the problem once back on the home front.
The reason for using a lighted switch is so that I'm aware when I am riding with by-pass on, reminding me to fix the problem right away. If anybody cares to know the procedure after I have performed it, I will be glad to document and and add detailed photos.
I got the idea from Mr. Skaggs and now I'm going to do it.
