1 - 12 of 12 Posts
All parts are brand new Honda OEM parts in the sealed packaging unless otherwise noted.
91351-HC4-003 timing inspection cover seal.
11514-MN5-000 right timing cover gasket.
11524-MN-000 left timing cover gasket.
1500 shifter seal 91206-286-013.
1500 All Balls rear wheel bearings new in box
1500 used u-joint. The joint is good.
KLR 650 stainless steel oil filter (reusable) new in the package.
1500 clutch slave cylinder used, but good.
1500 set of saddlebag stop wires front and rear
1500 oil seal for rear air shock part number 91257-KE8-003
1500 starter switch assembly magnetic part number 35850-MT8-000
1500 starter switch part number 35851-MF5-751
1500 carburetor bands (2) part number 16218-MN5-000
1500 miscellaneous body grommets 2 84103-443-611 1 17611-MB1-000 3 19113-MB1-870
1500 Reverse Bar switch part number 35370-MN5-003
1500 2 head set pigtails (the ones on the bike) used
1500 rear brake caliper new but not in package
1500 rear brake pads new but not in package part number 06435-MT8-405
1500 alternator wire used part number 31108-MN5-005
1500 reverse bar spring part number 24814-MN5-000
1500 clutch switches 35330-MB0-003 and 35335-MG9-951
1500 neutral switch part number 35600-MM5-003
1500 brake cruise control cancel switch part number 35340-MCA-000
1500 20 amp relay 38370-MN5-003
Some loose light bulbs not in the packaging.
That's a lot of parts. I am asking $160.00 shipped for all of the parts. That's well below half of retail. This would make a great stock of parts for your garage.
I also still have a full cover that is maroon that I am selling for $30.00 shipped.
Thank you,
Ed
what condition is the cover in and who is the manufacturer?
Sorry Fonz... I had said that I would take the 1500 speed bleeders... but my inbox had over 100 messages in it so I didnlt get anything you sent me.
I really am interested... it;s just that my box was full and I got super busy. (I'm a school teacher and district IT guy...)
I hope you'll feed back... PM
T
Hey Fonz,
I seem to have lost the message with your paypal info - could you please resend it so I can send you some money for the bike cover?
Thanks!
1 - 12 of 12 Posts
