OK so the 88-89 had 6 pins, 91 thru 2000 wheels have the same part # 42650-MW5-315. So even though the brake parts are different the wheels are the same.
I have a 1998 Honda Goldwing SE. I parked the bike about 1 month ago and was starting great. Tried to start today and will turn over and not fire. I have with a good battery. kill switch is in right position, all fuses are good, Reverse switch lights work. I pull one of the plug wires and no...
i need to replace the Left hand handlebar controls on my F6B
Should be the same as a GL1800?
I have no idea how????:confused:
Any help much appreciated (Full every Word Description)
Any Photos more appreciated
Thanks Heaps from the land Down Under
Hi there.
I have a LED light bar installed on top of the trunk lid.
It is wired in a way that even when the key is in ACCESSORY position it is on ( it blinks rapidly on and off when I apply the brakes)
This is the only light that works with ACCESSORY on, so I think it may me a separate...
Purchased an 84' goldwing for $50, seller said it ran good but he also decided to cut every wire hose and oil line. Just trying to get the engine running but the wiring diagram is overwhelming anyone have any advice on just getting the engine running.
Greetings gents,
Had bike down for a bit (6 months) due to time and other mechanical parts change (back wheel etc...)
Bike starts up no problem cold. After it warms up, it runs like poop. Sometimes I can hear the injectors clicking like crazy after it dies.
No fault codes...
Also, after...
