1 - 11 of 11 Posts
Senior Guru
I wonder what the ideal shift speeds would be?? :(
Probably some type of mod, because boat applications require fire arresters on the fuel system.
Looks like an 1100 setup of some type.
I wonder if it still has the radiator and has a "closed" system or if someone installed a raw water pump for a boat type "open" system.
I bet that think hauls butt! I think it'd be neat. Especially if you towed it with your wing!:shock:
hmmmm its different....
Tom
Those carbs look more like the pictures I've seen of the 1000 carbs.
Yea they look a lot like 1000 carbs.
certainly 1000 carbs. I think that guy should join the forum. We can use his talent.
I am with you guys anyone building a boat around a Goldwing motor most definitely belongs as a member of this forum. We need more Goldwing scientist!
Regards
Greener
1 - 11 of 11 Posts
