I always liked the AMP gauges better than Volt meters. Actually would like both.
Are there any good Amp ones, cheap, that look good and fit the 1500 well?
Volts are good to know, you know when the battery is getting a bit low or charging well, but allot they don't tell me.
Amp gauge lets you know if charging or not, just look at which side of 0 the needle points LOL
Also, get up to full charge and the needle reading close to 0 because no big load being powered, then flip on driving lights and watch needle jump. Easy way to see about how many amps the lights eat.
Flip on the heated gear with lights off, watch needle jump, tells you how much the power the gear is eating.
Volts, well about all that tells me is Alternator is putting out plenty of power to keep volts where they should be, or not enough if volts start dropping. Does nothing to really tell me how much power I am using for anything.
