Ok Guys and Gales, the old man is st.... st..... stu.... Stumped!!!
You thought I was going to say stupid...... You'd still be right...
3 Yellow wires:
I cut our the connector near the battery and soldered on 3 new, heavier wires. After I got all done, it started fine and I was able to run my 55w fog lights at idle and still get 13.1 volts on the dash meter, thats a first. Normally I can't run them very long at 3350 RPMs let alone idle. So there was a problem.
But then I got thinking about those other connections..... and found 2 up near the voltage regulator. 2 yellow wires go into and come out of one connector (with a bunch of other wires, and one wire goes into and comes out of another connector (with a bunch of wires).
Question: Where do I cut the wires and connect the wires from the stator to eliminate all connectors.
Heres what I have:
OK....... Then I have what appears to be 2 dog gone..... I mean Dog Bones Fuses. Which one do I replace with an inline 30 amp? If it;s just the top one in the pic, that easy. But how would I do the other one? It appears to be part of the solenoid?
Pic:
3 Yellow wires:
Heres what I have:
Pic:
