I hear a lot about the stock GPS in the Honda machine. I suppose most do not like it.
I however do like the Honda GPS and have to chalk some of the discontent with it up to the simple fact most of us do not know how to use the thing. This is all new to me, and I am no electronics or computer type person, it takes me time to learn about these things.
It is aggravating to have to spend two hundred dollars for an updated computer chip to have the latest roads and so on, but I do not feel it is a necessity to have this every two years. Some roads do change, just dissapear, and interstate ramps and so on are changed, but overall in ten years time, not a whole lot changes. Once you get used to the Honda GPS you learn to work it with a relaxed attitude and just go with what it does and trust it as it will eventually always get you there.
Sometimes the stupid thing will default to non-highway mode, so you have to check that often, I do not know why it does this, but it will at times default to that, and put you on backroads, I have had that happen several times, but even then it will eventually get you there. (all GPS systems have this fault even my Zumo)
You can even actually program a route with the Honda GPS, no you cannot sit and do it in your compurter and hook it up and program it, but you can just put way points and stops into a route on the bike, and program it in and go with that.
Over all I do like the GPS. On a long run such as the one we will go on this fall to Montrose, I do not have any set plan or adjenda anyway, I will just go till I get tired and then pull in to the closest motel, I have no desire to complicate my life with having to be somewhere at a set time, so just as a map, a guide the GPS suits me just fine.
Kit
