I just put grip heaters on my bike, and i love them. However...this has a been a month long headache, and I will tell you why. When i got them, they didnt come with glue. So i says to myself, no problem...I will just get some grip glue at the local bike shop. I installed the grips, waited a day, and all was good. Until i turned them on and went for a long ride. The glue got hot, and gooey, and the grips moved around; the throttle side twisted the wires 90 degrees around before i got home. I removed the grips, and cleaned all the glue residue off, and decided on another plan. So i tried some gorrilla snot weather adhesive...same thing happened. I dont think this stuff really ever dried....as the temps were around 40 or so. So off came the grips again...then i tried the golf club grip thing...which is double sided tape with a agent to allow them to set. this worked for a day or two....then, first long ride, same ol thing happened, grips got loose again. A senior member suggested big bike parts grip glue gel. Which is intended for heated grips, and has worked perfectly. several long trips, and no slipping of grips, and no movement whatsoever. Thanks Dusty Boots for the input, and curing my grip proplem. I hope this info can help anyone trying to install heated grips, or grip heaters, and save them the headaches i had along the way.
