jeffy1500 wrote:
AAA guarantees a show up time of 30 mins.
HA HA LOL
I do not remember that when I had them a couple years ago and I had to wait longer, but they say other things also that are not true!
They also say each member on the policy is allowed 4 tows per year up to 100 miles each for the PLUS membership too.
No problem ever for the 100 miles tows, I got some to home or a friends where I could make repairs myself. That was great.
Funny though, after being with them about 8 or more years they refused to renew me because of excessive tows! Each person, 3 of us, were allowed 4 tows each per year they claim, BUT NONE OF US ever went over 3 tows in any one year! But we were canceled for excessive tows!
I would have fought them over that, false advertising! But I lost the letter they sent me! They claimed the average member has only 1 tow or less per year but we had too many and cost them over $2200 in tow bills!
HEY, AAA SAYS NOTHING ABOUT COST OF TOWS! THEY SAY YOU CAN BE TOWED 4 TIMES A YEAR PER PERSON!!!
Me, Wife, and Daughter, 5 or 6 vehicles with 3 drivers, 3 drivers is 12 tows a year they advertise we can have! We never exceeded 3 tows each in any year!
True, I would say for about 2 years I had above average tows, still below what they advertise we are allowed though!
I was being sabotaged by a bad mechanic! I learned too late, either he was just plain ignorant and bad, or he was purposely attacking my vehicles and I believe the later though I can not really prove it.
But why would a car I owned for many years just suddenly have the starter bolts come loose and chew off the teethe on flex plate a week or so after having a water pump put on?? And the car was NEVER over heated, it just had a seepage where the pump was starting to go bad. Also the pump he put on shattered later (probably excessive tight belt) , broke more than in half, destroyed the radiator and fan, and when I replaced it I found wrong bolts and loose bolts from the work he did!
Same mechanic (last time he touched anything of mine) backed off my PU truck rear brakes all the way then tried to say my master cylinder was bad!
Simple easy, any fool with a Ford truck should know, and every real mechanic should know!
The rear brakes often DO NOT self adjust as they are supposed to! Brake pedal goes near floor, red brake light come on in dash, it goes out it comes on, etc...
Rear Brakes need manual adjustment!
This fool of a mechanic adjusts my brakes all the way off!!! I pay thinking correct, pullout of shop, pedal hits floor, brake light on will not go off. WORSE than when I took it in!! I say you backed off the brakes not tighten them, FOOL says the adjusters only turns 1 way and my master cylinder must be bad causing it!!!
I drove home with almost no brakes, jacked up truck, one side after fighting I got adjuster broke loose and adjusted correct, other side I had to pull the drum and use pliers on the adjuster to brake it loose FOOL has it forced so hard backed off! So I adjust brakes correct, full pedal, no brake light on dash, I drive back to shop and tell boss man I'd like my money back and why!
His brother was not there next time I went back which was a long time later!
Rather he was just that STUPID or if he thought I was and was trying to drum up more work for repairs not needed I can not be sure, though I know everything he worked on of mine before that ended up broke somehow and many needed towed, which is why AAA said I had too many tows and refused to renew me a few years ago even though we always had LESS than the 4 tows per year per driver they SAID we could have!
