I bought a GL1500 with 90K miles on it. According to maintenance records with the bike, it has been maintained well--at least oil changes & filters.
I would like to do a comprehensive maintenance schedule before taking it on a long trip. Here is what I've come up with, after searching this forum, the service manual and owners manual. Comments? Additional things to do? Some part numbers not right?
Comprehensive "100,000 mile" maintenance schedule
1. Change Oil & Filter: Shell Rotella T Synthetic 1 gal, Filter Pure One 14610
2. Change 6 spark plugs: NGK DPR7EA-9, gap .035", OR NGK Iridium Plug - DPR7EIX-9 (Gap .035")
3. Change Final Drive Oil 4.7 oz of Hypoid Gear Oil SAE 80
4. Change Coolant: First flush, then 1 Gal Prestone Extended Life, Silicate & Phosphate Free ethylene glycol
5. Change Air Cleaner Element: K&N GL1500 - HA-8088
6. Change Fuel Filter: GL1500 Fuel Filter VFR NT650
7. Change Air Pump Filters: 52716-MN5-003, 52717-MN5-003, 52718-MN5-003, dessicant 527A2-MN5-003 (38752-MN5-003)
8. Change Sub Air Filter element: 17253-KT8-000
9. Drain & Clean Crankcase Breather
10. Change Clutch Fluid: DOT 4
11. Change Front Brake Fluid: DOT 4
12. Change Rear Brake Fluid: DOT 4
13. Change Cruise air filter element: 36532-MN5-005
Inspect & Replace, as necessary:
1. Tires: Michelin Pilot GT. F: 130/70-18 63H, R: 160/80-16 75H
2. Battery
3. Timing Belts: Gates - #T275 (2 ea.)
4. Brake Pads: Front EBC FA124/2; Rear EBC FA69/3
2. Battery
