1 - 9 of 9 Posts
Hey gang,
While I don't use my hazards very much, yesterday we stopped to take some pictures and my hazards only worked on the left side and nothing at all on the right.
Any ideas where to start?
Thanks in advance.
Rick
If the right turn signals work normally there would have to be a break in the lt. blue wire between the hazard switch and where it splices into the right turn signal circuit.
No mice that I know of. And yes, the turn signals work fine and so do my new flashing rear view mirrors.
Where is the right turn signal circuit? I know where the switch is, :action:
Rick
The right turn signal circuit is a light blue wire that runs from the switch to the lights. Somewhere among it the wire from the hazard switch splices into it. I have no info on where that splice is but I suspect it is somewhere near the switches.
Have you checked the right ground wire? May be in the switch???
Nightrider1
Pwhoever
Sometimes it is just a dirty switch. I will sometimes have problems when it has been sitting for a while (winter) and I push the switch in. If I hold the switch in and wiggle it (when it does this) I have been able to get both left and right going. Usually a good blast of Electronic contact cleaner will help and then work the switch in and out several times.
Yes I would start by cleaning the switch with electronic spray cleaner, I could probably go out right now in the cold and have to work the switch a little to get both sides to work.
Good info guys. I will clean the switch today
Happy riding
Rick
1 - 9 of 9 Posts
