Head bearings
692 Views 6 Replies 6 Participants Last post by  OnaWingAndaPrayer
I have never rode another Goldwing nor been around any so I don't know what one should feel like.
I changed the head bearings and torqued to 14 ft/lb after preload and moving from side to side several times but something just don't seem right can't explain the problem too well but i still get a little of what seems to be a looseness in the front end.
I don't have a set of spring scales to check to see if the bearings are tight enough does any one have an idea for me? thanks, Mel
I replaced mine last year and torqued everything just like the manual said...still got wobble in the corners. So I went back and tightened the bearing nut about a quarter of a turn and now it rides great. I don't get wobble in the corners and I don't have the wobble that plagues the 1200s when you take your hands off the bars.
I think what caused my problem was the fact that I had the whole front end apart and up in the air. I don't think it let the bottom bearing seat properly. I should have put the tire back on and let the front rest on the ground...I think I would have had better results.
That's what I did...it worked for me but may or may not solve your problem...I would however at least go back in and retorque everything now that you have a few miles on it.
Loose fork bushings and loose wheel bearings can give you that feel as well as some tires and pressures.
How did the bike feel before the bearings were replaced? Did new bearings help at all?
I normally check my bearings when I have the front end in the air for whatever reason. I grab the forks and try to feel for any looseness in movement when pulling/pushing fore and aft on them, you will feel the slop if its there. I consider NO movement in this manner to be acceptable, and it isnt that hard to retorque the bearings.
Thanks for the replies. To answer some of the questions- I had a wobble in the front wheel before working on it. There is a definite improvement the tire was also changed with a new one, fork seals were replaced- used ATF for the fork oil,and the brake calipers were rebuilt. It rides much better but still feels a little loose althought with the front wheel off the floor I feel no looseness.I didn't replace wheel bearings. I guess I will go back in and retorque. Mel
I have no 1200 experience ,but on the 1100 family there is a high probability of head shake while decelerating . This mostly happens between 40 and 30 MPH . DO NOT take both hands of the bars , and it will happen with only one hand on bars even . IT is more likely tooccur with a worn tire . Again this is my experience with my 1100 .
All this said because you may feel its fixed today . A few thousand miles later the snake may show its head again when you least expect it . Just be aware and keep hands on .
