OK,
Recently took my '87 GL1200 Aspencade in for a head gasket replacement. (Probably should of done it myself). Anyway, went to pick it up and found the external small 6mm head bolt located on the bottom of the head leaking through the bolt. I have been lead to believe that the threads on the blockfor this bolt go thru into the oil sump or thru the block. (no backing) I have looked at the parts manual and a tech book but can't find any info on this problem. Am I on the right track or not? Has anyone heard of this and if so what is the fix. Myself, I was thinking a (non-locking) loc-titethread sealant.
Now the worst part was this side was not the one with the blown gasket and I had it done just to be safe, now I have a problem with it.
OK,
