There's no fun way to do this. Remove the chrome trim under the winshied, there are 2 phillips screws , one uner each mirror base that need to come out and then the trim will come off by sliding it left or right and lifting up a bit,then remove the signal lights and then remove headlight assembly. You will need to remove the trim under the headlight(2 phillips screws) to get to the 2 lower mounting bolts for the headlight, then there are 2 upper bolts to remove and take out the headlight. You will then see the headlight adjuster and cable. It's sounds worse than it is, but it's the only way I know to get at it because it's right behind the headlight. Have fun.
1987 GL1200 Interstate
Why do you need to replace it?
Is it broken, froze up or do you just dislike it?
I've never heard of one failing, but a friend thought the one on his LTD was shot because it didn't seem to make any difference on the road. When we took it apart it was working fine.
ut1w7b wrote:
the knob was broken on mine I could not adjust it. On high beam I could see the signs but not the road.
The knob comes off with a set screw and can be replaced without replacing the cable. That is a lot of work.
Meanwhile, just crank that puppy down. From what you describe it's going to take a lot of turns on the cable.
Also, make sure there's air in the shocks. :cooldevil:
If it's just the plastic knob, then you should be able to just replace that.
